Re: Farmall A 1-Bottom mounting??
Posted by El Toro on April 26, 2005 at 04:22:40 from (64.12.117.13):
In Reply to: Farmall A 1-Bottom mounting?? posted by WI jake on April 25, 2005 at 14:31:30:
Hi Jake, Send me your name and mailing address
and I'll send you a photo of my A with the plow installed. Hal
Post a Followup
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
