Re: pto dripping fluid. Where do I ad and check l
Posted by farmallhal on April 25, 2005 at 14:48:32 from (64.24.35.16):
In Reply to: pto dripping fluid. Where do I ad and check level posted by lekander883 on April 25, 2005 at 14:14:47:
Troy, You might have already identified the fill cap for the transmission/differential fluid but if you haven't it is to the right of the steering support post on the platform or transmission cover. You will probably need a 1/2" drive extension which should fit in the square hole. You might have to rig up some sort of special funnel to pour it in so as not to make it too messy. Just fill until it runs out the level hole Allen identified for you. My owners manual states to use SAE 90 wt oil. This should handle it except sounds like you will need to replace a seal or a gasket around the PTO shaft soon. Hope this helps. Hal
Post a Followup
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
