Re: Farmall H Hydraulics can't get it up (loader)
Posted by Hydrolic Pressure on April 27, 2005 at 07:26:14 from (64.80.110.33):
In Reply to: Farmall H Hydraulics can't get it up (loader) posted by greenie on April 27, 2005 at 05:15:22:
You ARE running out of oil. The belly pump only holds a few quarts, and you've got those huge 48" (or longer) cylinders to fill.
As someone else said, you have to plumb the top end of the cylinders back into the fill tube on your belly pump, and get them filled with oil. That way, as the pump sends oil to the bottom of the cylinder, the tops refill the belly pump so it can keep on pumpin'. On the way back down, the cylinders suck the excess oil back out and store it until the next time.
Post a Followup
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
