Re: which AMMETER is correct???
Posted by Doug in OR on April 27, 2005 at 07:31:05 from (159.121.94.198):
In Reply to: which AMMETER is correct??? posted by farmall john on April 27, 2005 at 04:59:31:
I can"t speak for what your tractor came with from the factory, but 30-0-30 should be plenty. I couldn"t imagine any charging system delivering more than 30 amps to the battery. Same goes for discharging; more than 30 amps means you are having big problems somewhere.
The real deal is to install a voltmeter. I presume you are using a 12 volt system. A voltmeter should be easy and inexpensive to install.
Post a Followup
