Re: Axle ratios, continued
Posted by CNKS on April 27, 2005 at 18:53:21 from (204.249.178.138):
In Reply to: Re: Axle ratios, continued posted by NDS on April 27, 2005 at 18:41:50:
NDS--You changed the radiator, so the trans cooler in the radiator was bigger? -- what happens if I simply bypass the radiator, and run direct to and from the external oil cooler? If I run transmission oil thru a 200-210 degree radiator, doesn't the external cooler just have that much more to cool? Have heard varying opinions on that. I asked the transmission place if I bypassed the radiator, do I need to run it thru the radiator in the winter -- he said it was impossible to overcool a transmission. I asked the same thing of a local mechanic (not a transmission specialist), he said to run it through the radiator....??
Post a Followup
