5088 Speed Transmission
Posted by Michigan Dave on April 28, 2005 at 19:39:38 from (63.27.216.175):
I lost the odd gears on my 5088 speed trans. When shifted to a odd gear the sentry light comes on and the tractor won't move. From reading manuals it sounds like it could be a bad pressure transducer. Any advice or other possible causes would be greatly appreciated. Thanks in advance. Dave
Post a Followup
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
