Re: which AMMETER is correct???
Posted by captaink on April 29, 2005 at 06:56:15 from (66.115.214.56):
In Reply to: which AMMETER is correct??? posted by farmall john on April 27, 2005 at 04:59:31:
To answer your question, how many amps does your charging system put out? If you are running a 12-volt alternator, you can get them to put out more than either the 30 or 60 amp ammeter will show. Under normal circumstances, a 30 will work just fine. As far as the Volt/Ammeter discussion goes, both are useful devices however neither alone will tell the whole story of an electrical system. The volt meter will tell you how many volts are in the system. If the charging device is in good working order it will show around 14 volts (+ or – a bit) while the engine is running and then settle back to around 12 to 12.5 when it stops. If there is a 3 amp drain in the system, the voltage will not drop enough on a volt meter to be noticed. Likewise, if the voltage regulator is starting to get bad, the ammeter may set on 0 or up an amp or two looking normal but the charging device may be putting out less than 12 volts. To get the complete story on a charging system you need both ammeter and voltmeter. However, the ammeter is the more common and in my opinion the more useful of the two in day to day operations.
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
