Re: CUB Update
Posted by gene (Missouri) on April 29, 2005 at 21:58:07 from (208.144.172.138):
In Reply to: CUB Update posted by GNB on April 29, 2005 at 18:34:24:
Even with the pointer pointing at the TDC mark on the front pulley you could still be 180 degrees out of time. The engine fires the #1 cylinder once for two revolutions of the crankshaft.
Try this. Remove the #1 plug. Turn the hand crank slowly until you feel compression building up on the #1 cylinder. Continue the rotation until the pointer indicates TDC.
Now check the rotor location. This will be your #1 plug wire. Rotor rotation is counter clockwise.
Post a Followup
