Farmall Tractors Discussion Board
Re: 460 problems...driving me nuts
Posted by Thud In GA on December 10, 1999 at 12:32:27 from (198.246.222.18):
In Reply to: 460 problems...driving me nuts posted by Steve NW WI on December 04, 1999 at 11:10:56:
Did you check the Coil, I don't think it's your
Carb. If a coil is going bad it will do what you
described under a load, You didn't say if you took
the load off that would run ok, or if you had to
restart it? If you had to restart it could you
do so right away? and did it run ok till you loaded it? Also if your gas cap isn't venting you
could see simular things.
Valve timing could be a problem also..
Post A Followup
: Re: Re: 460 problems...driving me nuts
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
