Is my Cub Lo-boy compression too low?
Posted by Bixley on April 30, 2005 at 20:32:21 from (12.161.152.2):
I did a compression test on my Lo-boy and got between 70-75 lbs on all cylinders. Is this too low? I put an electronic ignition on it which made it run better but still not good enough. It sounds great until you put any kind of load on it, then it starts spitting and sputtering out of the carb and is weak as a kitten. The carb has been rebuilt, engine timed and valves adjusted. One thing I question is the carb. I had to use two gaskets or else the throttle plate would hit and bind up on the intake manifold so I am not sure if it is the correct one, but it did run good with it at one time. Anyone have any ideas?
Post a Followup
