Re: Is my Cub Lo-boy compression too low?
Posted by Bob on April 30, 2005 at 21:03:19 from (66.163.134.177):
In Reply to: Is my Cub Lo-boy compression too low? posted by Bixley on April 30, 2005 at 20:32:21:
Compression that low across the board along with the other symptoms makes me wonder if the camshaft timing is off for some reason. Was it running good, and then it started acting up, or has someone had it apart, and it's never been right since?
Of course, it could be badly worn cylinders and rings.
Post a Followup
