Re: 49 Cub (threw the towel in today)
Posted by Dixieland on April 30, 2005 at 21:09:17 from (207.119.210.235):
In Reply to: 49 Cub (threw the towel in today) posted by GNB on April 30, 2005 at 19:43:31:
Hi G...Hold on there!!!I will help you do this. These may be stupid questions and suggestions but we gotta start somewhere. Are the plug wires connected to the distributor in proper order. The distributor cap should have a number one(1) indicating cylinder # 1 plug wire location. From there going clockwise facing top of distributor cap is # 2, # 3, & # 4 consecutivly. But, the firing order for connecting at the spark plug end at each cylinder is 1, 3, 4, 2. The front cylinder is # 1 then 2, 3, 4. Double check these and make sure they are correct. Next thing to check is, do you have the correct spark plugs? You may need a hotter plug to fire the old engine. If all that checks out the logical problem would be in the correct settings of your rocker assembly. If your carb is getting fuel and you have fire at the plugs your valves are not fully opening and or closing at the proper time. The easiest way for me to tell you how to do this is, take the spark plug out of cylinder # 1.Place your thumb over the hole and turn engine untill you feel air being forced out. As soon as you feel the compression shine a flashlight into the spark plug hole and watch for the piston to come to the very top of the stroke. Then do the same for cylinder # 3, then # 4, then #2. If you don't get the compressed air at these points and time, your rocker arm needs to be set so the valves open and close properly. If no compression is there, bring cylinder # 1 piston to top of compression stroke indicated by alignment of timing mark and flywheel mark. When these are aligned exactly, lossen the valve tappets untill the # 1 exhaust and intake valves are completly closed. With a feeler gauge adjust the tappets for .014" clearence between the tappet and valve. Then turn the crank handle engine for Your next compression stroke which will be cylinder # 3 and continue to # 4 then #2. Double check your manual for the proper clearance on your valves but .014" should be ok to get er runnin. I know this is about as clear as mud but it is a start. If you find these suggestions not to be the problem, post back and we will write some more...Good Luck...Dixieland
Home
| Forums
Today's Featured Article -
The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
