Re: 12volt battery in a 6 volt system
Posted by old on May 01, 2005 at 08:09:22 from (207.69.136.198):
In Reply to: 12volt battery in a 6 volt system posted by lekander883 on May 01, 2005 at 05:35:48:
Yes you can put a 12 volt battery on a 6 volt system but, if you are going to keep useing it that way you need to add a ballast resistor to the coil wireing. Also a good 12 volt battery will last a long time with out being charged as long as you don't have to start it often. Depending on the tractor its not hard to put an alternator on them, but some of the farmalls you almost need to find one from some of the Jap cars because a delco alternator will not fit under the hood.
Post a Followup
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
