Re: CUB TIRE/WEIGHTS REVERSING
Posted by old on May 01, 2005 at 11:15:36 from (207.69.137.135):
In Reply to: CUB TIRE/WEIGHTS REVERSING posted by HERMAN MOORE on May 01, 2005 at 10:51:06:
Did that to a cub last summer, found it to be earyer to pull the tire off the tractor with the center bolts, lay them down take off the weights and bolt them back on before trying to put them on the tractor again. If you try to put the weights on after you put the tire on they are almost to much to handle, but if they are on tire/wheel its not to bad because you have more to work with and more leverage
Post a Followup
Today's Featured Article - Identifying Tractor Noises - by Curtis Von Fange. Listening To Your Tractor : Part 3 - In this series we are continuing to learn the fine art of listening to our tractor in hopes of keeping it running longer. One particularly important facet is to hear and identify the particular noises that our ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
