Re: 12volt battery in a 6 volt system
Posted by Tommy Pierce on May 01, 2005 at 19:35:06 from (152.163.101.13):
In Reply to: 12volt battery in a 6 volt system posted by lekander883 on May 01, 2005 at 05:35:48:
I would ever put a 12 volt in a 6 volt system, you will burn up your starter and it want help your generator either. I have put a 8 volt in and bumped up the generator to keep the battery at 8 volts. It works good but still isn't the best on the starter. Make sure you have 2 gauge cables on the tractor and the generator is putting out properly. The old 6 volt is the best for a tractor that was built for 6 volt.
Post a Followup
