Re: 12volt battery in a 6 volt system
Posted by Hayfarmer on May 02, 2005 at 07:36:49 from (66.243.238.72):
In Reply to: 12volt battery in a 6 volt system posted by lekander883 on May 01, 2005 at 05:35:48:
I have converted 2 tractors from 6 to 12 volt using an alternator. I would not change either back. If you are not using lights and have a magneto the tractor may start quite a while on a battery with no charging system. If you want to go that way I would put on alternator. It is an easy conversion. As mentioned you need a resister in the wire to the coil or a 12 volt coil with internal resister. If your tractor is a "user" and you anticipate using lights on it or attached equipment this is the way to go.
Post a Followup
