Re: Problems with M
Posted by Randy SE-MN on May 05, 2005 at 05:01:00 from (206.9.216.46):
In Reply to: Problems with M posted by Innkeeper on May 04, 2005 at 22:57:01:
If there is mud int the air cleaner, and mud in the sediment bowl, there is probably mud in the bottm of the float bowl of the carb too, reducing the volume of fuel available fot the engine. On an unrelated note, you probably have an inch and a half to two inches of mud in your oil pan. Anything is possible. Definatly take a flashlight and look down into the fuel tank and make sure there is nothing blocking anything there. Good Luck...Randy
Post a Followup
