Re: Farmall M Foaming Radiator
Posted by Nat on May 05, 2005 at 13:48:22 from (64.80.110.40):
In Reply to: Farmall M Foaming Radiator posted by Farmallion on May 05, 2005 at 10:00:13:
Rusty's right. Foaming is caused by air being pumped through the water (like blowing through a straw into a glass of milk). Them 4 big pistons make pretty durned good air pumps. You've got a leak between the combustion chambers and the water jacket/galleries somewhere.
Post a Followup
