Re: Problems with M
Posted by captaink on May 05, 2005 at 15:04:34 from (66.115.214.56):
In Reply to: Problems with M posted by Innkeeper on May 04, 2005 at 22:57:01:
Others have eluded to the fact that there is a fuel flow problem and have suggested many places to check. One that I have found particularly frustrating is when the neck of the sediment bowl that screws into the gas tank gets plugged with old dead flies or other gunk. You can blow back into the tank, but often the plug will settle right back in again. If it appears that this is where the restriction is, I’d suggest taking the tank off, tipping it on the side so that the fuel cap is up and unscrew the sediment bowl and take it out of the tank. Blow the holes out where the fuel runs through and then replace it. I’d also check the inside of the tank to make sure that there isn’t more crud in there to plug it up again.
Post a Followup
