Re: 2404 international
Posted by Harold H on May 05, 2005 at 19:18:10 from (67.141.164.77):
In Reply to: 2404 international posted by bigearl on May 05, 2005 at 10:08:38:
The International 2404 is the industrial version of the International 404. It was built 1961-1968. The serial numbers are in the same numbers with the I-404 (not F-404). It is about 37 pto hp and 34 db hp. If your tractor is equipped with a rockshaft it can be fitted with a three point from a I-404. If it does not have a rockshaft it would be a major operation as you will have to change the transmission top and some internal parts with the complete setup from a donor I-404. Most all parts from the I-404 are the same as the I-2404. The main differences were the front axle and grille, color, and different tires and different options.
Harold H
Post a Followup
