Re: Will E-85 Work in Farmalls?
Posted by Chris Brown on May 07, 2005 at 04:37:33 from (209.206.208.41):
In Reply to: Will E-85 Work in Farmalls? posted by Ron Smith on May 06, 2005 at 16:10:47:
It'll run fine ,but you got to change the timing a little to get it right. You have to time it like a propane powered engine. You won't get quite as much power as real gas and it'll still burn a little more ,but it'll run fine. I have run several tanks through the 2N ford and around 100 gal through the K gleaner combine last fall. I don't know why the timing has to be advanced to run right,but it does.Also ,it will clean up the fuel system,so a new filter might be in order.
Post a Followup
