Checking RPM's
Posted by Andrew Z on May 07, 2005 at 07:02:45 from (64.252.224.57):
I want to check the RPMs on my A and I am unable to find anyhting that will test it. What devices work to check the RPM's? It is still set up using a Magneto. If that matters.
Thanks for the help
Andrew
Post a Followup
