Re: international 706 hi-lo-reverse shift lever
Posted by the tractor vet on May 08, 2005 at 08:20:02 from (4.124.82.160):
In Reply to: international 706 hi-lo-reverse shift lever posted by David Truesdale on May 07, 2005 at 11:28:09:
Ok lets start off with getting it set while in the nutral with the park lock in then star looking for lose linkage first the littel as i call them cub cadet tie rod ends then the headed pins down on the rod to the range shift lever and after ya got them all tighten up then it is time to pull the side cover off then the top cover off and fix or replace what all is woren in there . More the likely you have a couple broken rollers lose cam shift lever a broken pin loose key and a woren rev. shift lever and woren key and may be a broken shift fork. and a woren top cover this can be rebushed by a local machine shop but the hole must be kept in the center of the of original hole or it will not shift wright . Then after this is all fixed the ya got to address the clutch adjustment . Ya need to have 1 to 1 1/8 free traval then the transmission brake must be set this takes some help from a friend firs remove the pin on the trans brake then push the clutch pedal to the stop then loosen the clevis and hold it back and adjust till the pin will slide into the hole then release the clutch and add one turn to the clevis ( sometime it will take a couple of trys as i have had to at time add a half to a full turn to get it just wright because of ware on all the parts . Then ya got to adjust the dump valve and here again ya need help with the engine running back off the dump valve bolt about 6 or 7 turns then with the park lock ingauged push the clutch pedal all the way down to the stop and hold then turn the dump valve bolt in slowly till the oil lite goes out re lease the clutch pedal and then add one more turn to this bolt and lock the lock nut then the 706 will shift like a new one and nomore jerking on the shifter to get it in and out of gear. when done correctly it only takes two fingers to shift one .
Home
| Forums
Today's Featured Article -
A Question for Dads This recent topic from the Tractor Talk discussion board is being highlighted because it is an awesome display of the caliber of individuals that have made this site their own. The young person asking questions received positive feedback and advice from total strangers who "told it like it is" with the care many reserve for their own kids. The advice is timeless... so although it isn't necessarily antique tractor related, it will be prominently displayed in our archives to honor those who have the courage to ask and those who have the courage to respond in an honest, positive manner.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
