Re: Farmall M hydrolics and rear end fluid
Posted by Nat on May 09, 2005 at 05:24:16 from (64.80.110.40):
In Reply to: Farmall M hydrolics and rear end fluid posted by new2this on May 08, 2005 at 20:10:49:
Hydraulic fluid is a dipstick on the right side of the tractor under the gas tank, if your tractor has hydraulics.
Rear end lube is a pipe plug on the left side of the rear end in front of the axle housing. Drains front and rear in the center on the bottom. Fill through a big pipe plug on top next to the steering post.
You should look into getting a reproduction owner's manual for the tractor from a place like binderbooks DOT com.
Post a Followup
