Re: Farmall M hydrolics and rear end fluid
Posted by Nathan in Texas on May 09, 2005 at 06:40:07 from (216.167.183.158):
In Reply to: Farmall M hydrolics and rear end fluid posted by new2this on May 08, 2005 at 20:10:49:
The first 4 gears seem very close together to most I would assume.
Per the manual speeds are as follows for each gear: MPH forward 2-5/8, 3-1/2, 4-1/4, 5-1/8, 16-1/4 and 3-1/8 reverse.
The hydraulic oil and transmission oil are 2 different things as you might have gathered from Nebraska Cowman's post.
You can get a decent manual and service manual for about $20 or so online, if you plan on doing much work on it yourself it will be well worth it.
Make sure you lube all the grease fittings.
HTH, Nathan
Post a Followup
