Re: Proper direction of a thermostat on an M
Posted by Bob M on May 09, 2005 at 07:49:55 from (151.190.254.108):
In Reply to: Proper direction of a thermostat on an M posted by Nathan in Texas on May 09, 2005 at 07:02:58:
Several thoughts: 1 - It appears you installed your new t'stat correctly. You can quit worrying about that! 2 - As Bob suggests below, unless you're working the engine (or unless the outside air temp is approaching 100 deg...) it'll never heat up to the "RUN" range - even running on high idle. Reason: There's a passage cast in the t'stat housing that bypasses enough coolant around the t'stat to keep the engine cool even with a good t'stat installed. 3 - The OEM style temp gages are not exactly precision instruments - they tend to read low as they age/wear out. To find out if your's is reading low, remove the bulb and stick it in a container of boiling water for a minute or so. If it's in calibration the hand will move up near the top of the RUN range.
Home
| Forums
Today's Featured Article -
The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
