Re: ummm, rotor not lined up on distributor?
Posted by Andy Martin on May 11, 2005 at 12:16:02 from (64.219.39.195):
In Reply to: ummm, rotor not lined up on distributor? posted by arod on May 11, 2005 at 11:17:17:
You have the points just opening as well?
If so, you can pull the distributor out and rotate it one tooth or two to bring it closer into alignment. It does not have to be perfect, just close. In operation the spark is advanced so the rotor should not point before the perfect lineup, but a little after.
Post a Followup
