Re: ummm, rotor not lined up on distributor?
Posted by El Toro on May 11, 2005 at 16:14:48 from (152.163.101.13):
In Reply to: ummm, rotor not lined up on distributor? posted by arod on May 11, 2005 at 11:17:17:
You need to remove No1 plug near the radiator and hold your thumb or finger over the hole while someone hand cranks the engine over. You keep turning the engine until you feel compression against you your thumb. Once you feel the this compression look for your timing mark on the flywheel and slowly keep rotating the engine until
your timing marks are aligned. Both valves on No1 should be closed now. Look to see where your rotor is pointing, should be at No1 in the distributor. If it isn't gently pull distributor
and rotate the rotor to No1 and reinstall the distributor. Place the distr. cap on the distrbutor and look to see where No1 position is
if you can't determine where No1 is. I think it should be marked. Recheck the plug wires too. See which way the distr. turns I think most are
CW and follow the firing starting with No1, then
No3 is next, then 4 and 2 on a four cylinder. Hal
Post a Followup
Today's Featured Article - The Great Escape - by Dave Hollrah. It all began Monday with a little baling of second crop on the lake shore field, and as I drove out past my sister and her hubby's place, this small calling sound could be heard from the general direction of their manure pile. Out of the yard, over the cows and bale piles, through the dozer piles, poplars, and brush, out onto the ditch grade road, past the noisy 6.2 diesel engine pulling my well traveled Suburban along. Well it sure didn't take me long to figure out what it was because I alrea ... [Read Article]
