Re: SA Oil Pressure
Posted by Brian in Toronto, Ontario on May 11, 2005 at 17:30:50 from (69.158.175.107):
In Reply to: SA Oil Pressure posted by scott#2 on May 11, 2005 at 16:33:10:
I"m sure you will get more replies on this, but sounds like the oil pump cover which is on the bottom of the pump has become slightly warped. Very common on these tractors. When the tractor gets up to temp, the oil leaks out and the pressure drops. The solution is simple, just pull the pan off (make sure you get all the bolts including the ones at the very rear to get that pan off). The oil pump will be right there, just remove the pick up by taking out the cotter pin and pulling it out, then remove the cover, clean it up, run in over some emery cloth on a flat surface. I can"t remember wether there is a gasket or not, others will comment. That"s my 2 cents.
Home
| Forums
Today's Featured Article -
The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
