Re: Broken 706 throttle
Posted by andy r on May 11, 2005 at 19:41:14 from (69.66.148.88):
In Reply to: Broken 706 throttle posted by Farmall Daddy on May 07, 2005 at 22:12:27:
I have replaced the pin a couple of times. You do not need to remove the steering wheel to do this job!!!!! Once throttle shaft itself broke right at the top threads. I pulled the shaft out of the bottom and brazed the threaded part back on. Filed it round and reinstalled. So I know the shaft comes out from the bottom without removing the steering wheel or the casting under the steering wheel. This is much easier.
Post a Followup
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
