Re: SA Oil Pressure
Posted by captaink on May 12, 2005 at 05:39:58 from (66.115.214.56):
In Reply to: SA Oil Pressure posted by scott#2 on May 11, 2005 at 16:33:10:
As oil warms up its viscosity changes and it gets thinner. Because it is thinner, it moves through the small openings in the engine easier. This is good because then it is getting where it should and lubricating, but bad because it will also move out of where it should be through small holes or worn areas. Brain has a good place to start with the oil pump, and yes there is a very thin gasket which may also have a blown out spot. I’d suggest checking that first, my B had the same issues your SA does and I found a blown out pump gasket. If the oil pump doesn’t seem to be the problem or fix your oil pressure issues, then it’s time to pull the crankshaft bearings (both rods and mains) and check them for scoring or excessive wear. If that you find a bearing or bearings that are bad, then just because I’m a fanatic, I’d pull the engine and go through it from top to bottom and install new camshaft bearings. A lot of those old engines were overhauled “in frame” and the camshaft bearings have never been replaced. They do wear and can be the cause for low oil pressure also.
Home
| Forums
Today's Featured Article -
The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
