Re: 1972 454 utility 12v had a 6v coil?
Posted by Andy Martin on May 14, 2005 at 07:29:58 from (208.54.220.24):
In Reply to: 1972 454 utility 12v had a 6v coil? posted by n8terry on May 14, 2005 at 07:02:49:
IH was thinking like the rest of the industry. I don"t think anybody made a 12v coil.
GM always used a 6v coil with an external resistor wire. That was so the could give the coil 12v for starting,, directly from the starter solenoid.
Ford used a 6v coil with an internal resistor, so they marked it 12v. They could not give it 12v for starting like GM. That is what you bought.
Somebody probably removed the resistor.
A 6v coil runs fine on 12v, but the higher voltage burns the points. Since the 12v coil has an internal resistor, it is fine to use if it will run.
Post a Followup
