Re: I need some suggustions on 404 hydraulics
Posted by Jeff311 on May 15, 2005 at 19:26:01 from (205.188.117.138):
In Reply to: I need some suggustions on 404 hydraulics posted by Jrry on May 15, 2005 at 04:33:18:
Jerry,
This is Jeff in INDY...might try taking the large line loose on the inlet side of the filter and rigging a make-shift oil supply to force feed the pump to help prime it. I think once you get pressure flowing and suction started, the oil pickup that you installed on the rear top cover should prime itself. Might also be a blocked bypass valve and sounds like the vet may be able to walk you through those scenarios.
Post a Followup
