Re: farmall A electric.
Posted by Janicholson on May 17, 2005 at 10:54:38 from (199.17.6.175):
In Reply to: farmall A electric. posted by tractor-ernie on May 16, 2005 at 16:57:14:
The answer is to check out a book (old) from a local library, on Generator systems. There are also many posts in the archives here for polarizing Gen systems. I believe your described technique is not correct for Delco systems, they require volts to energize the field.
My 2 cnts. JimN
Post a Followup
