Re: how to install an OEM voltmeter on my Farmall
Posted by Bob M on May 17, 2005 at 11:44:24 from (151.190.254.108):
In Reply to: how to install an OEM voltmeter on my Farmall H posted by arod on May 17, 2005 at 11:13:02:
Arod - If your tractor is negative ground, connect the voltmeter "+" terminal to the switched (coil) side of the ignition switch. Connect the "-" terminal to a good ground.
(For a positive ground system simply reverse the connections at the voltmeter...)
Post a Followup
