i464 brake problems
Posted by Tim Carter on May 17, 2005 at 20:44:44 from (64.12.117.13):
I have a 1977 IH 464 gas burner with no brakes. I was bushoging Tractor ran out of gas backfired sevral times and then quit. I filled the tank up started the tractor, ran fine but no brakes. I checked the flow of the pump. Looked at the hose thatfeeds the brakes hydro fluid had some type of strainer-check valve in it Blew it out it was fine. Also transmition was getting very hot did not know if oil cooler was working but it was. I still can't get any pedal Tried to bleed brakes no luck Ifeel the mastercycl's are good any suggestions?
Post a Followup
