Re: Super H Stuck in gear help
Posted by Janicholson on May 19, 2005 at 08:13:11 from (199.17.6.128):
In Reply to: Super H Stuck in gear help posted by Sighombre on May 19, 2005 at 06:56:27:
I believe it is unlikely that the balls/rails and springs are at fault here (I may be wrong). I would be sure that the drive train is not under load (tractor can be moved by hand, back and forth some). Next I would use two screw drivers to gently try to tease third gear out of engagement on the shaft. Be gentle and don't bend anything. If it is stuck, it may have to be dissassembled to free the gear.
LOL JimN
Post a Followup
