Re: Need to replace 5th gear in an '48 H
Posted by Little H on May 19, 2005 at 14:38:08 from (65.204.92.51):
In Reply to: Need to replace 5th gear in an '48 H posted by molinebuyer on May 19, 2005 at 11:37:37:
you will have to take the transmission top cover off.
sometimes it isn't the geat that is bad but the shifter.
mine did this and i had to replace the shifter no the
gear. it is a big job so go slow and make sure you
remove the steering shaft supports belt pulley etc.....it is
best to have a parts book and the service guide too.
Post a Followup
