Re: Need to replace 5th gear in an '48 H
Posted by riverbend on May 19, 2005 at 21:14:12 from (208.160.34.150):
In Reply to: Re: Need to replace 5th gear in an '48 H posted by Little H on May 19, 2005 at 14:38:08:
Manuals are good. I only had the IT manual when I did mine. Once you get the top cover off, it is not so bad. If you had the parts you needed, it would only take half a day. Do check all the bearings while you are in there.
Post a Followup
