Re: farmall H, 12V resistor smokes after wiring l
Posted by Bob M on May 20, 2005 at 10:43:42 from (151.190.254.107):
In Reply to: farmall H, 12V resistor smokes after wiring light posted by arod on May 20, 2005 at 09:57:46:
Arod - A smoking ballast resistor can mean a couple things: 1 - You somehow got a drop of oil or similar onto the resistor. The smoke is the stuff being burned off by the hot resistor. (Note: It's normal for a new resistor to smoke for a minute or two the first time it is powered up.) 2 - Your new light wiring somehow managed to ground the coil side of the resistor. Now when you pull the ignition switch this fault current passes thru the resistor causing it to heat up. Suggest this: Temporarily disconnect the wire between the resistor and the ignition coil at the coil terminal. Now turn on the ignition. If the coil doesn't heat up/smoke with the wire disconnected, there is no problem. Reconnect the wire and forget about it. However if the resistor still smokes with the coil wire disconnected, begin looking for a short somewhere.
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
