Re: 12 oh 6
Posted by Aces on May 20, 2005 at 15:39:24 from (4.164.168.91):
In Reply to: 12 oh 6 posted by Larry806 on May 20, 2005 at 15:02:27:
Larry Yes it could be the lines. Here is the deal buying the tractor as he did maybe the lines were not all the same as for instance the 806 would have had different lines than the 1206 and the 4100 would be fifferent yet. The orifice in the end of the line at the injector is different. So who knows what it has on it, you will have to find out what a 1206 should have for orifice diameter and check them all. A line off a 806 opn a 1206 will make it run bad a line off 1206 on a 806 will make it run bad. The other thing we run into on the 56's was they needed an extra spring in side the pump to steady the govener, you might try it if the lines don't do the job.
Post a Followup
