Re: farmall super C don't start
Posted by El Toro on May 21, 2005 at 04:25:10 from (205.188.117.138):
In Reply to: farmall super C don't start posted by donny on May 20, 2005 at 18:40:01:
Here is a troubleshooting method for checking your ignition system posted by Wayne Swenson last month. No spark? Clean and dry the distributor
cap. The following info is assuming a battery-coil ignition.
1. Is there battery voltage at the coil? Use a
test lite or volt meter.
2. Is there battery voltage at the points? Use
3. Remove distributor cap, rotor, points cover
& remove the coil wire from the distributor cap & put it within 1/4" of a ground.
4. With points closed & ignition switch on, snap the points open a few times and watch for spark at the coil wire end.
5. No Spark, may have burned or dirty points, a bad condenser, or a bad coil. Coil primary (battery voltage) wire to points must be attached to + on the coil if your battery + grounded.
You may want to run off a copy of this for your files. Hal
Post a Followup
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
