Re: M Oil Pump Removal
Posted by El Toro on May 21, 2005 at 07:50:36 from (64.12.117.13):
In Reply to: M Oil Pump Removal posted by JBlavl on May 20, 2005 at 05:30:42:
Hi Josh, I think you should pour or spray some lacquer thinner around the block where the oil pump is installed. It's ideal for removing vanish
and may loose that pump too.
Where is that pump installed on the engine? Most are driven off a gear on the rear of the camshaft. Would be nice if you had access to the gear on the pump and could pry against it. Would removing a freeze plug help?
Just some thoughts. Be sure to watch the Preakness today. This a big event in MD. Hal
Post a Followup
Today's Featured Article - Maintaining Rubber Tires - by Staff. The broad use of rubber tires on farm tractors and machinery has resulted in a great saving in both time and operating costs since the time of steel wheels. There are, however, certain basic fundamentals in the care of tires that should be followed carefully if the owner is to derive maximum benefit from his or her investment. First and most important is to maintain proper pressure for the work at hand. Your best guide to proper inflation is the operator's manual or instruction book tha ... [Read Article]
