M Oil Pump Removal
Posted by JBlavl on May 20, 2005 at 05:30:42 from (199.197.135.1):
Having a little trouble removing the oil pump from the block of my M. I took the two bolts out that hold it in place and tried to pull it out. Nothing. Rotated the cam and pulled at the same time and nothing. Is there an additional bolt someplace I can not see? I don't want to beat on it because it looks like it is cast and hammers and cast don't mix. Any suggestions?
Post a Followup
Today's Featured Article - Maintaining Rubber Tires - by Staff. The broad use of rubber tires on farm tractors and machinery has resulted in a great saving in both time and operating costs since the time of steel wheels. There are, however, certain basic fundamentals in the care of tires that should be followed carefully if the owner is to derive maximum benefit from his or her investment. First and most important is to maintain proper pressure for the work at hand. Your best guide to proper inflation is the operator's manual or instruction book tha ... [Read Article]
