Re: Hard Starting
Posted by El Toro on May 21, 2005 at 16:27:31 from (205.188.117.138):
In Reply to: Hard Starting posted by Nik on May 21, 2005 at 14:32:38:
Your compression is low. Could be stuck or worn rings and a worn cylinder. You need to double check that timing. Bring No1 piston up on compression to TDC. Mark the timing mark on the flywheel with chalk. Have someone hand crank it slowly while you hold your thumb over the plug hole. Once you feel compreession against your thumb stop cranking for a moment and look for timimg mark. Once you see the mark, slowly keep cranking until the timing mark is aligned with the indicator on the clutch housing. You need it right on the money, then remove distributor cap or mag cap and look to see where the rotor is pointing. Should be at No1 plug wire. No1 is near the radiator. Hal
Home
| Forums
Today's Featured Article -
Preventing Tractor Theft - by Staff. The discussion started with the following message: I have a JD A without key start or any locking device. Is there a best way to secure it so the chances of it being stolen are reduced? Following are some of the answers that were received: Take the rotor out of the distributor and hide after each use. The would-be thieves at least couldn't just get on and drive away.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
