Re: Hard Starting
Posted by PAULIH300 on May 21, 2005 at 16:47:53 from (205.188.117.138):
In Reply to: Re: Hard Starting posted by Nik on May 21, 2005 at 16:33:21:
You pump shop air into the cylinder using an adapter that fits into the plug hole.You then listen to where the air is going:Out the muffler its exhaust valves.Out the carb,its intake valves.Out the oil fill cap,its rings....etc.
You could also have a gauge on the fitting,killing the air flow and with both valves close,watch if the gauge drops meaning a leak.
Post a Followup
