Re: 6 volt Farmall 130 not charging
Posted by El Toro on May 22, 2005 at 03:50:08 from (152.163.101.13):
In Reply to: 6 volt Farmall 130 not charging posted by KMG on May 21, 2005 at 19:18:09:
You need to hook a a volt meter across the battery terminals and see what your voltage is
with the engine at 1/2 to 3/4 throttle. Should be around 7.5 volts. Make sure all wire and battery connections are clean and tight. If the
voltage is ok you should check the electrolyte
(battery juice) for state of condition with a hydrometer. Battery could be getting weak. Hal
Post a Followup
