Re: 6 volt Farmall 130 not charging
Posted by Bob M on May 22, 2005 at 06:13:05 from (69.205.121.248):
In Reply to: 6 volt Farmall 130 not charging posted by KMG on May 21, 2005 at 19:18:09:
Punch below for a troubleshooting chart. It'll lead you thru several steps (including grounding the generator field) to determine what the problem is.
Good luck!
Post a Followup
