Re: Farmall H 12 volt switch over!
Posted by old on May 22, 2005 at 20:58:31 from (207.69.136.204):
In Reply to: Farmall H 12 volt switch over! posted by Dick Bunch on May 22, 2005 at 19:15:22:
I've had good luck with useing an alternator from a toyota pickup. They fit under the hood well and not hard to hook up. You can even use the same mounts as the genny just need a long bolt if I remember right. As far as the coil you just need to get a balast resistor and put it in line with the coil. One for a dodge works well.
Post a Followup
Today's Featured Article - Identifying Tractor Noises - by Curtis Von Fange. Listening To Your Tractor : Part 3 - In this series we are continuing to learn the fine art of listening to our tractor in hopes of keeping it running longer. One particularly important facet is to hear and identify the particular noises that our ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
