Re: Farmall H 12 volt switch over!
Posted by Doug in OR on May 23, 2005 at 10:39:31 from (24.20.250.197):
In Reply to: Farmall H 12 volt switch over! posted by Dick Bunch on May 22, 2005 at 19:15:22:
I've heard that the regular Delso 10SI works, but is tight. You can also use an alternator from any small import car. An old Toyota alternator works fine. Don't worry about the alternator capacity - even an old 37 amp alternator will give you plenty - twice the power out of a 6 volt generator. As for brackets, you can usually use the same lower bracket by simply using all-thread and spacers. The upper bracket is not a big problem. Find a piece of 3/16 inch by 3/4 inch steel and bend it as you need to. You will need to add a ballast resistor in series with your coil. An inexpensive MOPAR resistor works. If you want to installation to be cleaner, you can buy a real 12 volt coil. Be sure to get one that specifies "no resistor needed". Good luck.
Home
| Forums
Today's Featured Article -
Identifying Tractor Noises - by Curtis Von Fange. Listening To Your Tractor : Part 3 - In this series we are continuing to learn the fine art of listening to our tractor in hopes of keeping it running longer. One particularly important facet is to hear and identify the particular noises that our
... [Read Article]
Latest Ad:
1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
